http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-490
hello everyone! ima build a new sub, and it's going to be di-polar. i was thinking of using 2 of the above ^^. has anyone used these? if i can't get those, then i'll get the 10" version. what i'm looking for is anyone who has had experience with the 10 or 12" versions of those! thanks!!
bump, and i bought the 10" version. should i run sealed or vented? oh btw, my sn is lemans23 over at caraudio.com, so i know plenty about audio, just in case u were wondering if u could get technical with me.
You said at first it might be dipolar. Here’s the best source:
www.linkwitzlab.com/models.htm and other links at the Linkwitz site
With 10 inchers you could (as in the Linkwitz Orion, two drivers a side, with EQ) make it dipolar say 50-130 Hz, with sealed boxes below.
It would be difficult to go diploe & get it right first time. Vented would be cheaper easier.
