Just finished doing a lot of testing on the LD22C LD22F tweeters and thought some may be interested in a look at them against the LD25X (discontinued) tweeter.
More info from CSS will be coming but just had to give a little info
These tests were done on a .25cft PE cabinet.
Todays testing with the same 3 tweeters on a cabinet with width of 10.5".
CSS LD22C
CSS LD22F
(discontinued LD25X)
Mic was not moved nor the cabinet rather tweeters were swapped out and measurements were taken less than 2 minutes apart.
All the measurements will follow from Bob I wanted to let a little info out for those looking wondering and or waiting.
CSS LD22C
CSS LD22F
Why was the LD25X discontinued?
Without going into all the details there was basically an inconsistency in the build quality which resulted in too great a variation in the parameters and performance.
Bob
Too bad. I liked the design concept, especially with the corrugated surround.Without going into all the details there was basically an inconsistency in the build quality which resulted in too great a variation in the parameters and performance.
Bob
