New caps vs old no difference
Hello everyone. Im new here. Looking for help. Wanted to upgrade caps to new ones but there is no audible difference. Does this not make sense that caps are biger newer, maybe better built. Cant hear even little difference.
Please add more details:
  • what is the device you are working on?
  • where is the signal "going" through the capacitors?
  • yellow ones are originals, red-brown combos are new ones?
  • how are you listening for the difference - speakers, headphones, what is the source signal?
Obviously, the manufacturer went to great length in constructing this thing, and they likely chose good, suited parts. Then: These film caps do not degrade and there is no real technical advancement in that area, so the original caps might be as good as anything you could buy today,
Check the original schematics and reinstall the original part, that is IMHO the best you can do. If you want to do something for the peace of mind, you could select a cap of similar value, select by looks and price. The shown construction is is plain awful and hurts my eyes 😱
If you have awful audio output, you might want to check the non-film caps in that area, as those can go bad.
Reactions: gerrittube
Hi madis64
Cambridge Audio CD3
Is going to rca output
Yellows are originals yes
Listening on tube amplifier and HPM110 speakers, also tried headphones and active genelec speakers. No Same no audible difference.
Signal source is cd from cd3.
