Hi all,
Its been a while since I've put together a pa set up was retired basically. Covid brought back my love for audio, now heres where I'm stuck, I have a behringer autograph with sub out, an alesis 3630 compressor that I will use for protecting the signal from blowing my bins, and a peavey cs 4000 amp which will run my twin 15s reason for this is the tops are rcf active.
So any advice I would appreciate. Currently I was looking at cutting the subwoofer point at approx 85hz - 90hz.
You are asking for advice, but I'm not sure what you are asking for in terms of help. What do you want advice on?
