Hello guys,
I`m wanna build my first amp. The choices are:
1- Amp based in LM3875 CI or something similar
2- AN 948 (http://www.diyaudio.com/forums/showthread.php?threadid=2236&highlight=Hex or a modifcated version http://www.diyaudio.com/forums/showthread.php?threadid=6041&highlight=AN948)
The intention is use the amp with this Preamp : http://www.normankoren.com/Audio/Spice_preamp_2.html#NewPhono (the purist version) that presently I`m building...
Which do you recommend? LM version or Mosfet?. Any advice will be apreciated.
Thanks a lot
Marcelo.
Thanks a lot
Marcelo.
I would go with the lm3875...seems to be simpler than the hexfet designs...and they are pretty good sounding as far as I can tell...
For a first amp, a Gain Clone type device would be ideal: easy construction, plenty of advice (and opinions) from other builders and very easy construction.
Try other, more complicated, designs when your GC is to your satisfaction!
Nice one,
David.
Nice one,
David.
why not try both? I am looking also at a p3a or Nelson's Mosfet citation 12 (essentially the same as an948).
Does anyone realize that Motorolla also has a 100w/200w highperformance amp in their application notes?
Thanks for your answers guys.
Well, the idea is bi amp. First I wanna build a Mosfet Amp for mid/high frecuency. The LM3875 amp for woofer???
...I don`t know
Marcelo
Marcelo
Where? I can not find the Ap in the motorola web site
Thanks.
Marcelo
it is available from On Semi, the ex-Motorola semi conductor business, titled "100 and 200 watt high fidelity audio amplifier utilizing a wideband-low feedback design". It uses the 3281/1302 twin.
http://www.onsemi.com/pub/Collateral/AN1308-D.PDF
enjoy.
enjoy.
- New Amp: Hex-Fet or LM 3875
