New Amp case?
Hi all, I just bought a 12 space amp rack and want to know how to wire the 19" neutrik panel, it has 8 punched holes for NL2MP. My question is I would like to use this amp rack in 4 way stereo system so I will have bass, mid bass, mids, hi. So I would like to use 12 gauge speaker wire out from 19" panel but how do I wire it to the amp since rear NL2 MP +/- metal tabs are small and want to use 16 gauge wire to banana plugs to the amp, is it safe to use a smaller gauge wire soldered to the thicker 16 gauge wire?
Any suggestion on how you connect your racks? Thanks!😉
I am going to be using speakons between speakers and the 19" D Neutrik panel which has the 8 pre punched hole for the NL2MP. My question is is it ok to use 16 AWG wire between the back of the MP's since the metal tabs are quite small so a small wire solder a thicker 16 AWG wire to Banana plugs to amps? Thanks!
