New AlephX - problem
Hi...
I have put together two channel of Aleph X...
One is working fine, except that heatsinks are little short so that temperature is 65*C, but the another gives me problem...
I just connected it for the firs time...and one side doesn't work?
When I say one side, I mean, when we divide this amp to + and – output side...Q1, Q2 doesn't work...Q10, Q11 does work...( I have 2xQ1,Q2 and 2XQ10,Q11 )
I measure voltage over source resistors on those mosfet and I get 0.5V on Q10, Q11 and 0V on Q1, Q2...
I try to swamp Q5 and Q7 and I get same thing...
What could be wrong?
Moderator
Joined 2003
Could be, just take them out for the moment, the amp works fine without them.
In any case, you need exactly the same voltages at R23/25 and 2.9V is too low. Measure the voltage across the gate resistors of the output and current source mosfets.
They all should read 0V. If not, the corresponding mosfet is broken.
/Hugo
o.k....I replace ztx450...no change...
Change Q7 ( IRF9610 ) on R25 (¨the one that measures less then 0.4V ) ... no change...
I try to resoled resistors around Q5/Q7 ( on PCB )...no change...
Is there possibility to burn something while playing with this...I mean one side work, other don’t and there is above 10V on PCB ?
Netlist, thanks for your time and hlep :)
