http://www.arcade-electronics.com/c..._catid=243&sid=7@mDZ21En7rl3Dg-16105447801.9c
Arcade Electronics that SKLIMEK posted has the same thing
but if you want to call the place near me
www.cablesandconnectors.com
they have it too.
Oh, for my Aleph 2's, i used a 280k resistor for r19, and 2k for r21, then put pots across them, 100k and 2k respectively to adjust bias and ac current gain...this way there is always a resistor in the circuit when i put a switch and fixed resistors in...so i can switch bias and ac current gain to a lower level when i want to run the amps at low power
-Matthew K. Olson
they have it too.
-Matthew K. Olson
Banned
Joined 2002
fcel said:Jason,
Per what Matt said, could you include a pot (for extra fee) that would fit the board as part of the kit so that we're able to adjust the bias to our liking? For A30, I'm not sure which is the bias resistor though. From my recollection, 200K pot is good to start with.
Matt,
Do you happen to have the address of Berlin TPK? Do they do mail order?
Give me the digikey part number and ill put them into all kit's ( if price is cheap enough )
j'
AC current gain
Matt,
Thanks for the link. And the suggestion - an easy way to adjust bias!
Regarding adjusting DC bias and AC current gain, let's say the target is 3A for your Aleph 2, you'll adjust R19 FIRST, and then R21, UNTIL the meter reads 3A? I'm trying to refresh my memory regarding adjusting AC current gain.
Matt,
heres a pretty good link using a 200k trimpot for bias adjustment that I found trying to get everything straight in my head as well;
http://www.diyaudio.com/forums/showthread.php?s=&threadid=8727&highlight=
the procedure for R21 is alittle more elusive but look here;
http://www.diyaudio.com/forums/showthread.php?s=&threadid=51808&highlight=
Netlist provided a link that takes you to Nelson article on page three for ac bias adj.
also, the WIKI on The AlephX talks about ways of going about it.
I actually went to sleep thinking of R19 and R21 one night trying to sort it all out. How sad is that?
Stan
Stan
You don't have to do it the way i did. 100k and 1k pots will work fine in place of r19 and r21. I have not tried adjusting r21 yet, so i don't know how much it'll effect bias, though i think bias effects ACIG more than ACIG effects bias. I'd set the bias first, its amazingly stable, then fiddle w/ acig until you're satisfied. I doubt the meter will move much while you are adjusting acig. I could be wrong though...haven't done it yet. Soon maybe this weekend i'll fiddle w/ it. Later!
-Matthew K. Olson
-Matthew K. Olson
PierreG said:To BrianGT
I already ordered and paid for the mini Aleph PCB but....Is it too late to order a Power Supply PCB?
No, it isn't too late. Just place another order and I can combine the orders and refund the extra shipping.
Brian
Banned
Joined 2002
Coulomb said:Brian does C1-C3 220uF need to be 50V? Can it be 35V?
Your parts list calls out an IRF044, but the general consensus was for an IRFP240 was it not? The 044 has twice the input capacitance as the 240 but half the RDS.
Anthony
They have to be IRFP240's..
Then that is what your half A**** spread sheet should say!
Anthony
Anthony
As far as I have read, the 044 should work better when there are no parallel devices. I listed the IRFP240 for the Aleph30 amp with parallel devices. I am sure that the IRFP244 will work fine for the Mini-Aleph version as well.
As for the caps, use your own judgement, I listed 50v for all kits, as they fit on the board. Lower voltage caps should be fine for lower power setups. (for all of the caps on the boards)
Brian
BrianGT said:
As far as I have read, the 044 should work better when there are no parallel devices. I listed the IRFP244 for the Aleph30 amp with parallel devices. I am sure that the IRFP244 will work fine for the Mini-Aleph version as well.
Brian
Hummm it makes more sense to go with one FET for all applications I think, so the IRFP240 is what Jason wants. You have no objections design wise correct brian?
Anthony
Banned
Joined 2002
leejh said:Brian
Is it too late to order PCBs?
No, I still have extra boards available for both the power supply and amp boards. Boards have shipped, and I should get them on wednesday.
I will disable the order page if I run out of boards.
Brian
The power supply boards arrived today. They are substantially thicker than the gainclone boards. They look quite good. Here is a pic:
I will put up more pictures soon. The amp boards should be here tomorrow, as they shipped a day later.
Brian
Brian
Banned
Joined 2002
Here is Brian's SMD board on my 8 x 8 Inch Heat sink's Im starting to worry that my heat sinks might not be enough : O (
big enough
I built a stereo aleph50 using 4 heatsinks a little bigger than the one in the picture. Mine are about 9 x 9, the reason it became a stereo 50 was because it ran too hot with the rails and idle current at the correct point for an aleph60...
With an ambient of 20c each of the sinks I have is good for about 75w with the fins vertical and a surface temp of 55c, I used 4 devices on each of 4 faces, arranged to make a cube... though I'd could probably have got lower temps using more parts, I just didn't have enough matched.
If all else is equal you should get approx 80% of the cooling performance from each one of the plates you use, so ~60w...is that enough for what you are trying to make?
Stuart
Stuart
Banned
Joined 2002
- New Aleph Mini PCB GB
