Jason-
I guess we are all a little too eager with these kits. Have you already ordered parts for the 4cap kits? If not, let's figure out the price difference and see if people would be will to pay the difference, then we can all get the new boarsa and kits. Hopefully the price difference won't be too great. One alternative would be to use the new boards and only use 4 caps. Who knows.
Brian, will the price of the new boards be higher? I think I already paid for the boards too, but I actually am starting to get confused about what I have paid for (building 4 amps at the same time is most confusing).
WorkingAtHome said:Jason-
The pricing for the boards will not change, regardless of which ps board design is chosen. Jason hasn't ordered any parts yet, and we will work something out.
The new PS boards work with either type of capacitor.
Brian
4-pin caps
Brian,
What are the advantages to the new caps your board now accomodates? Larger Capacitance?
Thanks,
Ryan
Brian,
Thanks,
Ryan
Re: 4-pin caps
The older caps still work. The newer caps offer higher capacitance.
The only drawback to the new caps is the size. The Panasonic TS-UP caps are offered in a lower profile, which wouldn't really be an advantage to the Aleph designs, since the heatsinks will have to be relatively large anyway, making the chassis profile relatively tall.
Brian
Still accepting Aleph PCB orders:
http://www.chipamp.com/aleph
PS board poll
http://www.briangt.com/gallery/PS-poll
RKH said:Brian,
Thanks,
Ryan
Brian
PS board poll
On a side note, I ordered the pcbs today, 3 oz copper, blue soldermask, 0.093" fr4, with a 2 week leadtime. Hopefully they will ship sooner (AC has been good with this and often ships a few days early). This means that in 2 weeks, I will have the boards in my hands.
I went with the larger 6 capacitor power supply board, and will post pictures/info tonight on the final layout.
I ordered extra pcbs, so I am still accepting orders:
Brian
Brian
Im helping my friend build an aleph 5 with these boards. this question was asked before, not sure if it got answered. By setting the board up for aleph 30, is it just a matter of raising the rail voltage to achieve aleph 5 status. looking at a30, the schematic for the input stage (esp around diff pair)is slightly different, everything else seems to be the same, except for a few different values, a5 with higher input impedance
what changes if any would be needed to make a5.
john
john
Nudge
Bump
Bump
Not only that. Hit up passlabs and compare the schematics for A30 and the A5. Check the amount of Mosfets on the output/CCS, the source resistor values and the railvoltage. Also the size of toroid/supplycaps and so on. Propably some more issues also. Its all in the schematics🙂is it just a matter of raising the rail voltage to achieve aleph 5 status.
Steen.
Its basically the same. Source resistors for A5 are 1R, A30 has .47R. 3 fets for output and 3 for ccs for both. i know the input is a bit different for the A30 which results in a higher impedance for single ended input (i think). i studied the schematics but im a bit new at this
thank you
John
thank you
John
no help?
i'll just go for it, change the source resistors to 1R, and raise the rails, using irfp244. Anything else?
If you are in Newington, i reccomend you go down to the Berlin TPK and go to Cables and Connectors. Pick up a 10A CALRAD?current meter( they are $17.99 each) to measure bias current. Put one in series with one of the rails coming off the power supply and you can measure bias current. I'm in Farmington, and i did this was my Aleph 2's so i could easily monitor bias current. Boy does it make things easier. You might also want to consider starting w/ pots for ac current gain and bias so that you can set those to your liking. For my aleph 2's those were r21 and r19 respectively.
I doubt this answers your question exactly, but it may help overall. 🙂
-Matthew K. Olson
-Matthew K. Olson
hmm, got $150 worth of gift certificates for that place, that place is awesome, they moved next door now its huge!!!
thanks for the advice, my meter has a current clamp so i should be fine. saving up for that lab power supply.
John
John
I'm talking about a chassis mount meter. 🙂
But yes, Cables and Connectors is really nice to have around. I get most of my stuff online, but there are a few things i only get at Cables and Connectors. Heatshrink is one, pcb stuff, and calrad meters 🙂
-Matthew K. Olson
-Matthew K. Olson
i Pick up a 10A CALRAD?current meter( they are $17.99 each) to measure bias current. Put one in series with one of the rails coming off the power supply and you can measure bias current. I'm in Farmington, and i did this was my Aleph 2's so i could easily monitor bias current. Boy does it make things easier. You might also want to consider starting w/ pots for ac current gain and bias so that you can set those to your liking. For my aleph 2's those were r21 and r19 respectively.
Hi Matthew, that does sound like a nice trick for biasing R19 w/ the chassis amp meter, especially because I "believe" I was reading in a search that it takes awhile for the current to reach its maximum point (maybe thats' why some people say their Alephs sound best after warming up for an hour. I couldn't find it at cables and connectore (web site) but I believe this is it?
http://www.arcade-electronics.com/cgi-bin/webc.exe/st_prod.html?p_prodid=19393
You could take it out when your done or whatever. This "30" is my first Aleph and I have been reading on the biasing quite a bit, I've got R19 (DC bias) figuered and R21 (AC gain) figuered at least mentally but I was wondering about R16? Can't seem to find to much info in searches and I have noticed that it was one of the key resistors in Brians BOM that indicated an adjustment might be necessary after biasing (?). Any thots?
Best - Stan
Best - Stan
Thats the one. Leave it in. Put it in the back of the amp. Its not terrible looking, but i didn't find it worthy of the front of the amp. The amp i have does not bias slowly. I turn it on, immediately bias goes right to 4A/rail and stays. 🙂 I like having a meter built into the amp. Peace of mind kind-of-a-thing
-Matthew K. Olson
-Matthew K. Olson
I should receive the boards in a weeks time. The status shows the boards in the final phase 🙂
Brian
Brian
Joined 2002
BrianGT said:I should receive the boards in a weeks time. The status shows the boards in the final phase 🙂
Brian
WICKED!!
Parts are all being ordered on friday. Kits will be put together next week i hope.
Jason
Jason,
Per what Matt said, could you include a pot (for extra fee) that would fit the board as part of the kit so that we're able to adjust the bias to our liking? For A30, I'm not sure which is the bias resistor though. From my recollection, 200K pot is good to start with.
Matt,
Do you happen to have the address of Berlin TPK? Do they do mail order?
Matt,
- New Aleph Mini PCB GB
