trigon said:You could use a bright BLUE LED instead, just my two cents😉
Trigon.
But then the amp wouldn't look like a burning furnace.😉
Very nice. So, now I know why you didn't hang around forum lately. Appart from the power differences, I got the impression than SOZ could be a better sounding amp, right? Maybe finally, I should finish mine as well. 😉
Well the picture isn't to good. The amp looks like a big valve amp, witha warm light coming from the inside.
I was on another thread, trying to repair a Sony amp. with the help of our e-friends, I actually did it!
I feel the same way about SOZ. Simple is ALOT better to me, at least.
when you listen with SOZ for a while, the lack of power vanishes.
The big difference is when you make a side by side test. Big muscle amps have strong arguments.
I have a NAD 3020, that also compared with SOZ side by side looks better, but a more profund listenig session reveals the that brute force isn't better that a simple circuit.
I bet the only reason NP doesn't sell SOZ amps is because his clients don't want to buy a amp for the price of a car with only 5 or so Watt.
Also worth mentioning is that environmental light is crucial to the critical listening. I will be using an old green tube from an old tube vacuum cleaner. It is an reminder on good old days. I think it is a good idea.😉
I recently bought a house that I'm renovating.
I will have a dedicated small (9m2) audio room, just for my amps speakers and records.
I plan to use this aleph, My valve amp and a lava lamp for the lightning. no wall light switch! heheh
Great work, and thanks again for helping me with my Aleph 5. Can you pick that amp up yourself? Good luck with the house.
Nice work Pedro!!! I like those heat sinks....finally another person that has gotten away from those boring flat type sinks! I considered that type for my amp too, but the price was more than double the 300.00 U.S. that mine cost me.....
Those sinks make a nice statement.....
Mark
Mark
Very nice PedroP0, but I thought you had finished the amp earlier 🙂. I have seen photo's of the 2 halves finished, so I thought he has only put the front lid on it.
Aleph
Hi Pedro!
Nice looking amp. I'm hoping this amount of heatsinking is not absolutely necessary because I was planning on building an Aleph 5 with two heatsinks I've got laying around somewhere.
And, while mine are quite "substantial", yours are huge.
But, while your upgrading your house, you might consider getting bigger doors. You can then use a forklift to get your amps from the workshop to the listening room😉 😉
Greetings,
Jarno.
Hi Pedro!
Greetings,
Jarno.
Pedro,
your Aleph looks very good ! Great work on the SoZ as well !
What speakers are you using ? Eventually the 'Claw' will be the fitting speaker for the 'small' powered amps and also serve as a new challenge once all the currently available designs have been built ...
Andreas
Andreas
Very nice Pedro
Too bad we can't hear it, but the look is great. I like the high spikes. Gives it a more "female look".🙂 😎 And with the light bulbs inside...aahhhh, everyone has his fetishes...
Hugo
Hugo
PedroPO said:another one.
Very nice piece of work.
Do I see a tube amp in the back at the left???
He stated on the first page:
I have a Audionote valve amp with 9W (300B SE and no feedback also) and lack of power is not so evident, just in the bass department.
So yes you've seen it correctly 😉
trigon said:Just take and look at this pic![]()
Just love those old tunning green tubes. In pt we call them "magic eye". Is this the proper translation?
MikeW said:Great work, and thanks again for helping me with my Aleph 5. Can you pick that amp up yourself? Good luck with the house.
Yep! it only weights 30kg or so
If you are not in shape, put some wheels instead of feet. (or a skateboard😀)
Re: Aleph
You are right. there is no need to use six heatsinks sinks. in fact only 4 of them are "working". the temperature is about 50ºC on the sinks with the fets and 30 with the sinks with the trafos.
Jarno said:Hi Pedro!
Greetings,
Jarno.
ARAD said:Pedro,
What speakers are you using ?....
Andreas
Infinity Delta 50
Hi!
I am also interested in you power-switching-solution, since I also plan to use a "vandalism-proof" button, since they look so nice...
You said that you used a bistable relais, I could not find it (since my catalogues are at home, and I am at work). Is there a kind of transformator build into the relais, or do you have to use an extra transformer in order to get some DC voltage to switch the relais? Sadly you did not post pictures where one could see this, so instead of looking I'm asking...
Great amp, sadly I cannot afford heatsinks like that when I start building my DoZ, so maybe I will stick to a defunct car amplifier heatsink....
Thanks,
Arndt
Thanks,
Arndt
yes. here it is😉
Cradle22 said:Hi!
Arndt
This is a relay that works with 220V AC, no trafos.
Just plug it into mains, a push button and that's it. take a look in this thread. I posted the serial #, brand and price.
here is a pic and link to datasheet
http://www.findernet.com/en/pdf/S26EN.pdf
- New Aleph 5 (finally )finished
