sealed or aperiodic box is probably one good solution - my plywood has quite a warp and don't want to risk warping the driver - might have another piece in better shape (?)
Got some 2x4's? You could likely un-warp and stiffen that ply by screwing a couple of long pieces in the back.
Thanks for clarifying - I'm happy to be corrected on that. Have you heard this driver - do you know how it would compare with the Fane ?
Never heard the Fane... so can't comment on that.
Have heard the Alpair 12P though - nice sounding driver and more dynamic than the smaller Alpair 10P. However IIRC it does not go as low as the A10.x variants.
Hope others got a fane.
Mcm says they're on back order for 97 days !!!!!!!!!!
Mine is in the mail.
I'm thinking 3ft3 sealed under TV (1:1.618 ratios) as center channel.
Then I can bring out and hook up my sub, but have to remove thiel and double 15's.
If agreeable (with notch), invest in 2 more and get an outlaw audio preamp.
sounds like I'm either mono or center channel (there's so much great music from the mono era) -will be interested in your opinions.
Lol, been reading yours and Nigel's.
I'd like Godzilla to play with one too, but he has a 12lta.
I remember poultrygheist preferred 12lta to 1808.
I wonder if I would have kept my Philips 12" if I tried it as a center.
Fane just seems fun bang for the buck.
12lta = useless without a "helper" tweeter - unless playing 78's and the later of those can subjectively benefit from more on the top as the ticks and HF surface noise kinda dither (like some tape hiss) - 12-250TC is an interesting bag of tricks
Hmm.
I remember Dolby digital sounded really glassy way up there sometimes.
The celestion 200tc died past 8khz ( like the fane 200lt), I thought that'd work for home theater rolling up there.
I almost got the cele with its box friendlier qts.
Fane 250tc haaaaaaasssssss to have a shorting ring.
And paper cones seem unoffensive to my ears.
Some people's ears don't like Kevlar/paper cones.
I'm glad we have some 12" full ranges choices for under $100.
Any of these could become a classic.
Norman
Norman
Norman, I'd love to try the Fane but funds won't allow it at the moment. I agree with freddiy that the 12lta needs a tweeter. It's wide range but not full range.
Lol, np.
Maybe a ribbon on top of 12lta cab or a micro dome "on a steeeck" like the hammer dynamics super 12.
A question about a similar driver the Eminence Beta 12 Lta. Having read up on phase plugs I noted most people seem to get good results regardless of the device shape. As a crude attempt to see what might happen I held various objects as close to the dust cap as I could. Despite being very close some difference could be detected and one or two seemed nicer. Perhaps a cylinder supported from the front very nearly hitting the dust cap can work? My crude trials seemed to show even when 1" from the cap something positive was going on. It seems when close to the driver the wizzer front edge is mostly helped. The baffle is 2' x 4'. It is half MDF and half ply made from 2' x 4' x 1/2" sheets.
I am dubious about removing the dust cap as I don't see a vented magnet and low movement as a cause of nonlinearity. If memory is correct a dust cap also reduces IM distortion ? I have 3 foam rubber dampers to the wizzer.
One thing I did try was a low mass baffle( polystyrene ). It seemed not to return energy to the cone in the same way. The sound seemed better. Highly impractical alas.
I think a phase plug disperses highs from bouncing around the inside of the whizzer.
I'd like to install one, but not until I have a few in case of ruining it.
You could loosely attach felt onto the dust cap, or older altecs had a hole in the dust cap.
I assume the dust cap can produce some highs, but can be a liability when the highs get trapped under it. Looking at pictures, it looks like a vented pole piece ( the backside).
Exactly Norman. In saw that some people did what I tried. A childs ruler and the centre of a toilet roll might be something ( end blocked ). Use the 12 in unit fixing holes to hold it . Crude, but something.
Yup. My buddy is convinced he can diffuse 1-4khz.
I can't see how it would not mess up 4khz and up.
But a phase plug will be in my future.
Norman
Norman
I was reluctant to cut the 12lta dustcap but am glad I did. The sound was better. I think the phase plug helped too but just removing the dustcap improved the sound of the 12lta. Maybe the Beam Blocker accomplishes a similar result?
- Full Range
- New 12" Full-Range: Fane 12-250TC
