...... With ability to add first order high-pass and plot resultant response ....
I used to use BoxPlot for this, but cannot get it to run with Win8.1 .
Primarily I simply need to input Qts, Vas, Fs, and Vb and then add
a high-pass filter and plot the output response ...............
What the world needs is a 32bit BoxPlot 🙂
Jeff Bagby's Woofer Box and Circuit Designer can do that:
Loudspeaker Design Software
Note that this program is a dressed up Excel spreadsheet. It has some issues when run under Excel 2013, but works well under earlier versions.
Thank You.....🙂
I can't open it (so far) other than read only. (Apache Open Office)
I'll try again in the morning.............
