Needed: Resistor value for Phoenix Gold RX600.5; Schematic would be ideal
I am looking for the value of R16 on the PG RX600.5. It was the resistor near one set of the rectifiers. It is no longer in circuit (long story).
It would be great if someone had a schematic, but based on my research, PG diagrams are not readily available.
  • overview w arrow.pdf
  • R16 2 w arrow.pdf
    R16 2 w arrow.pdf
This is unfamiliar territory for me as I primarily deal with home audio gear but here goes. There is a pair of rectifier chips (MUR1620. . .) a little closer to the input side of the amp compared to the power side. The center pin of the rectifier chip marked with the + sign connects to one leg of R16. The other leg connects to a pair of 2200 uf 16 volt capacitors.
Based on this, I assume this is part of the SMPS circuitry, but I could be off base.
