Need to MAke Pioneer Spekers
I have two
Pioneer TS-G1630 80Wmax 20Wnorm 4ohm
and two Subs
TS-W201F 250W max 100Wnorm 4ohm
and I would like to make two subwoofers and
two bookshelf sized speakes with these!🙄
I dont know how to calculate internal volume, Dimentions,
Port Size, Port Location and so on:cannotbe:
I also dont know how to determine wich in Vented or Sealed
enclosures will be best for these speakers!
I was hoping to use WinISD but it doesn't have my Speaker Parameters! & I could not locate them anywhere!
So Can you plese help me in the dimensions and what type of enclosures to use!:idea:
I'd like to use them in my sound system! as I dont have decent speakers!:nod:
The woofer can go anywhere but the Bassbox calculations assume that the port is on the same face of the box as the woofer, or close to it at least.
the vent dimentions are under the "box properties" in the pic.
Dv = diameter
Lv = length
An optimum 10L enclosure is 348mm x 215mm x 133mm, all dimentions internal, same for the woofer enclosure.
