I am trying to make a new crossover for some old KEF drivers I have but I can´t find data for the T-52 Tweeter from KEF.
If anybody has any info or the Thiele Small parameters please help.
Greetings
Greetings
Hello Promitheus,
here the data from the KEF T 52 B ( taken from the Lautsprecherbuch Hifisound)
fms 910 hz
Qms 5,13
Qes 5,92
Qts 2,75
Sd 11,9
Re 8,5 Ohm
Le 0,12mH
8 Ohm
100 Watt
87db
Voice Coil 39mm
3mm high
Grüsse
Jochen Sonnenschein
fms 910 hz
Qms 5,13
Qes 5,92
Qts 2,75
Sd 11,9
Re 8,5 Ohm
Le 0,12mH
8 Ohm
100 Watt
87db
Voice Coil 39mm
3mm high
Grüsse
Jochen Sonnenschein
Does anyone know the differences between The KEF T-52 and the much older T-15? I know that the earlier one was rear mounted and the later front mounted but the actual domes look very similar from the outside.
