Need sub woofer controller
Cute little board on e-bay. But,
You want a sub controller, so you know you are looking for more than just a crossover. There are several approaches. One is the LT kind of circuit if you are doing a sealed sub. (On ESP) Another is more of a parametric filter. (also on ESP) Years ago there was one product that was a 5 band eq for 250 Hz and below with a crossover. Nifty. You could adjust the frequencies and Q of any equalizer circuit to do this. Again, I think ESP has a project like that. Another approach is to use a DXC or MiniDSP. Far more flexible. I recommend you visit the Linkwitz site and read what he has to say about sub controllers. My experience, the variable phase is useless. I move my subs around and do better by making use of the room.
Evaluate your needs carefully. Right now, none of my three systems with subs use any eq. The rooms combine with my speaker designs to be just about right. Only one of the systems has an external crossover. Again, by designing as a system, the two smaller systems with plate amps use the internal crossover. Only my main system where I run two subs off a Parasound amp has a complete 4th order two way LR crossover. A modified Behringer actually. One of these days I should build a nice FET high pass instead. Anyone got a good handy design?
Nice. Combination of a parametric filter and a crossover. I very much like the 4th order on the woofer so you don't localize it. Second at 80 Hz ( THX) I can. The two systems where I use a plate, the subs are very close to the mains, so 60 Hz second works OK. The above mentioned design would still need an additional crossover for the mains.
I did run across a FET crossover design on Enjoy the Music.
I would seal the mains and use a LT-cirquit creating an acoustical HP function = 12 dB/oct @ 80 Hz Q=0,707 in series with a conventional 12 dB/oct @ 80 Hz Q=0,707 HP-filter to create a perfect 4:th order LR HP-function.
You could also use just a plain 12 dB/oct HP-filter leg like in most surround receivers, but then I would use a 30 dB/oct LP-filter with adjustable Q to make provisions for optimal integration.
I also like steep LP-filters. They really make a difference.
