Need some help to repair Crown 400 CSL
I found some more data. I am not sure what IOC1 is or how it relates.
I can see that it is not able to hold a bias point. Now you have to discover what has failed. I would take a DC voltmeter and measure the output voltage. It should be at near zero volts. If it is not then you have a bias problem that you have to trace. You do have your good channel to use as a reference which should make your repair much easier. Most failures happen in the high temperature parts of the output stage or the parts driving the output stage. Don't look at the input circuit until you have verified the output circuit.
  • Thank You
Reactions: myfirstamplifier
