Need some help finding the correct ferrite beads.
Hi guy's
Iám building the es9018 diyinhk dac and I have some trouble locating the correct ferrite beads on mouser.
I need 4 ferrite beads for FB2 tm FB5 the only thing it say's in the description is 2A 600Z What does 600Z mean? 2 amps with 600 Ohm? or is 600z the form factor of the smt parts? I have about 5 MM space max.
I also need one very small bead above the oscillator but the only thing the description say's is Ferrite bead 0805. Max space is about 3MM from the outer edge of the pad's
I don't know which one to choose..
Any help would be much appreciated
Here are some SMD ferrite beads in the 0805 package, rated for 2 Amperes, with an impedance of 600 ohms. I personally do not know whether these are the beads that the DIYinHK designer means; maybe they are. Maybe they are not.
