Need some asistance with Foobar2000.
So far I have not had any trouble getting the program setup and working pretty much flawlessly. I have not been able to get milkdrop to work at all. I have the foo_vis_shpeck.dll part setup right I think. Just anytime I go to initialize milkdrop It crashes out and locks up foobar.
I am on Win7 x64 with the 32bit versions of everything. I can configure milkdrop through the plugin so I'm pretty sure that part is functioning. Also It only seems to see AVS and Milkdrop 1.04. not V2 which I also have in the winamp plugins directory. Winamp works fine with either version. Also I can get AVS to work in Foobar no problem if I select it. Just not Milkdrop.
There has to be something simple I am missing.
Is it possible to use Milkdrop V2 in Foobar?
EDIT: The error I get is.... The plug-in crashed during frame rendering. LOL, ya think.
