Need schematic for 9v DC PSU
HI
I need a psu to power a 9V DC motor, this is the motor supplied by Scheu with thier TT. It has a small PLL circuit already in the motor case, so i think i just need a good stable 9V supply.
This is also an exercise for me so i dont mind going a bit OTT.
cheers
Andy
penance said:
HI
cheers
Andy
Use a large 12volt lead acid battery as your voltage source before the regulator. Charge it up once every month or so and you will be set with a noiseless voltage source that is easy to regulate with a simple LM7809 or better. Put a large cap after the regulator.
