Hi
I do repairs on all sorts of "Stuff", mostly early tube gear
I have a old Peavy SS amp, a PA-120, four channel mixer amp.
It is mint, inside and out.
The driver transformer primary is open, need another.
I could take off a junk amp, about a 50-100 watter amp.
Same as old Vox also.
Any help Thanx a bunch🙂
I found the schematic here: http://www.peavey.com/media/pdf/manuals/pa120.pdf and not much info on the driver transformer, other than its Peavy p/n "DG 298". I'd try Peavy for the part. It has low-Z secondaries to drive the output transistors, which makes it harder to find.
Otherwise, Sowter transformers has some good British steel and a vintage clone service they provide.
