Need pre-amp with LM358
hello.
the lm358 is a conventional ic,not really an audio ic................
you can try to use a typ. audio schematic where you swap the ic's to the lm358.
example:tone control
greetings
mjf showed you one in post #2
Almost any opamp data sheet has a tone control shown as an application... and any opamp will work.
Here's another, perfect for a TL072
Edit... actually the one in post #2 has an error... the opamp inputs are shown incorrectly (reversed).
