NEC FC20X1SA-AB
Paste that into google and the search comes up with a source, also a data sheet.
Data sheet:
http://www.wolumen53.com/pdf/fc20x1sa.pdf
Data sheet:
Try contacting MedShare. They collect and repurpose surplus, scrap and waste medical supplies and equipment.
www.medshare.org
www.medshare.org
Just in case that you do not find one same as yours I have one that it is a NEC 2 lines x 20 characters FC20X2JA same connector as your are but it is smaller. I think you can use it but you need to modify in the way it is mounting since it is smaller. I have 3 spares. I think it will worked just using one line. You can communicate RS232 or parallel. Let me know if your are interesting.
Attached are 2 pictures showing the display.
