Hi
I recently bought a Kindermann CPD Video LCD projection panel without the power supply or the VGA cable.
Does anyone know the voltage/current rating for the panel and as it has a 26pin LCD connection would an ASK VGA cable do the job.
Thanks in advance
Thanks in advance
i think it's a OEM of the ASK Impact 400.
We're here in germany (µView) offer those replacement cables for 12.90 Euro + Shipping (UK would be 6.00 Eu).
For powersupply you can use the normal Proxima OVation 820 PS (Pinout on : http://www.virtuel-blue.de/diybeamer/howto/proxsupply.htm
if you're interested so mail me info@nView.de
Bernhard
Bernhard
Hi
Thanks for the response. I managed to get hold of a 12v power supply and an ask cable and it works a treat.
Many thanks 🙂
Many thanks 🙂
I have an ASK Impact 400 and managed to make a cable to run from VGA. According to the manual it has a built in scan converter and will accept composite signals from videos etc, do you know how to make a cable for that input? which pins on the 26 pin plug do the signal and grounds from a composite signal go. Thanks in advance.
Hi alchemist,
take a look into the Manual sheets on www.ask.no, you get figure out there the input (download the manual, ther're the pinouts inside)
Bernhard
Bernhard
