Can anyone here give me the specs of this inrush limiter? I've looked all over the net and found nothing on it at all. Looks just like any other GE inrush limiter... It does exist as I have one sitting in front of me on the desk. If I knew the specs I could match it to something close enough...
Thanks,
Mark
Thanks,
Mark
As a GE number CL-100 is obsolete. If you look here the 101 is linked as a possible alternative but if you go to the linked page and look at the spec sheet you'll see that the CL-90, 101, and 110 are quite different , all three of which the DigiKey page for CL-100 lists as possible alternatives.
If it were me I'd go here and pick out something that actually matched the application . Digikey sells them all and if you want to talk over what's best for the app the engineer at Ametherm is very helpful.
Thanks for the tip. I was trying to find out the specs of the original part so I could cross it to something usable. I'm also waiting for the manufacturers schematic comming from Italy (IREM). Orignally it had some similar European made part equivelent a CL-100 in there... Appears to be one in series with each of the capacitors... 4 in total.
Mark
Mark
