Need Impedance Meter suggestions
Hi, folks
I've just been building my first set of speaker enclosures according to a friend's recommendations, and I need to get a decent impedance meter that won't cost me an arm and a leg.
Does anyone have any suggestions for which models to watch for?
Also, are there any alternatives to purchasing a meter? Can I rig up/use my Digital Multimeteror or Oscilloscope to test impedance?
-Thanks for any suggestions.
-Erik.:smash:
Hi Centauri,
You mentioned in another SW thread I started, about a mic preamp linked to from the speaker workshop site, but I can't find the link 🙁 Do you have it?
I've ordered some WM-60AY mics from digikey, so I'll hopefully be getting some proper testing done after Christmas.
Regards,
Tony.
edit: Erik, there are two versions of the walin jig here is a link to the newer one http://www.gti.net/wallin/audio/jig2/jig2.html I bult the first one but I'm going to redo it I think.
Thanks Centauri,
I found those yesterday but wasn't sure if they were the ones. I'm kicking myself I didn't ask about this before I ordered my mics, as the opamp in the second preamp I can only find at farnell, and it's about $6 more than if I had have included it in my digikey order, would have made the $17US postage that bit more worth while 🙂 ... Oh well.
Did you use veroboard/matrix board, or did you make a pcb? I've never made my own pcb's maybe time to give it a try.
Oh and that link I put in for Claudio's web site is broken (cut and paste didn't work......
It should be: http://planeta.terra.com.br/educacao/claudionegro/english/
Regards,
Tony.
I used veroboard, and built the thing into an unused pro dynamic microphone housing - a battery compartment and jack socket (with battery switching) where the grille used to be, and a RCA socket at the normal connector end that my mic and long brass tube plugs into. This allows me to use the setup in a normal mic stand (although backwards), and keeps low level signals short. I used the original mic's on/off switch as the gain switch, however due to this being large and right in the middle of the area involved, I used 2 dual opamps instead of the single quad opamp - just made it that much easier to jam it all in...
Cheers
