I live in Mumbai, India and I am building a Fender Champ 5F1 clone. I need help locating some of the components needed to build this sweet little thing.
Follwing is a laundry list of the parts/components that I need to buy:
Tubes:
1 - 5Y3GT
1 - 12AX7
1 - 6V6GT
Sockets:
1 - 9 pin miniature (noval)
2 - 8-pin large (octal)
Capacitors:
1 - 16uF 450VDC
2 - 8uF 450VDC
2 - .02uF or .022uF
1 - 25uF/25VDC
Couple extra 25uF/25VDC bypass caps
Resistors:
1 - 470 ohm
2 - 1.5k ohm
1 - 10K
2 - 22K
2 - 68K
2 - 100K
1 - 220K
1 - 470K
1 - 1 megohm
Pots:
1 - 1 megohm
Switches:
2 - SPST toggle
Fuse:
1- Fuse socket.
First off, I want to know who sells these triode tubes in Mumbai. Any addresses and telephone numbers would be helpful. Then I need a turret board - who can make it for me? Or is there a place where I can get the turrets to make my own board. Else I would be stuck with a perfboard.
Second would be power and output transformers. Who makes customs? Would someone be able to provide any addresses and telephone numbers? 240VAC primary on the power transformer and a matched output transformer (forgive me if I sound noob but I am fairly new to all this.) I also have some PDF specs on what kind of transformer I am looking at.
Third, do you guys see any of the components listed above as difficult/impossible to get. If yes are there any suggested places where I can order them.
And last but not the least, I need a decent 8' speaker for my amp probably 8ohms impedence. I have been told that guitar speakers are specialised and differently voiced and I am sure that they are hard to get in these parts. Can someone recommend a decent speaker that I can get started with?
I do not wish to sound like I need to be spoonfed or something, but I do not intend to re-invent the wheel. If you guys already know where all this stuff can be found then it would be great help to me. In any case I am going on a recon mission to Lamington Road this weekend. Will have my set of updates then. But if I could have some prior info or leads, then I could get started with procuring some of the stuff on my first visit.
Any help is appreciated. Thanks for reading the long post.
Emersa
Tubes:
1 - 5Y3GT
1 - 12AX7
1 - 6V6GT
Sockets:
Capacitors:
1 - 16uF 450VDC
2 - 8uF 450VDC
2 - .02uF or .022uF
1 - 25uF/25VDC
Resistors:
1 - 470 ohm
2 - 1.5k ohm
1 - 10K
2 - 22K
2 - 68K
2 - 100K
1 - 220K
1 - 470K
1 - 1 megohm
Pots:
1 - 1 megohm
Switches:
2 - SPST toggle
Fuse:
1- Fuse socket.
Emersa
