I'm looking at a friend's Hartke HA4000. I'd like to pull the small board that hosts the output jacks, but I can't seem to remove the connector blocks that connect it electrically to the other boards.
Most of the other connector blocks in the amp have both a male and female part and so separate easily, but these don't want to budge; I managed to pry one partially out (a couple mm) and it looks like the crimp connectors go through the holes in the board, instead of sliding on to pins as I had expected... 😱
Can someone lend some advice as to how to disconnect these connectors? Are the designed to even be removed?
