Need help with headphone jack
Disabled Account
Joined 2006
I've never had a pair apart, but from the posted link the clue is the label that says 'in-phase'. Also both drivers have white connections which suggests that is ground, i.e. common (even if it changes colour to black at some point).
So, the 1/4 jack has three connections known as Tip, Ring and Sleeve, hence it is often known as a TRS jack. Tip is left, ring is right, and sleeve is ground. So I would wire it as follows...
Tip (left) yellow
Ring (right) red
Sleeve (ground) white and black
That'll work I am sure.
hello.
i opend the jack of my good old akg.........red=right,yellow=left and the other two are soldered together to ground.............o.k.
greetings...............
