Hey All,
I am looking to build a decent console stereo system for my garage workspace. I would like to have a clean sound on low, mid and high. I want to listen to the radio, vinyl, and digital files (through phone and/or laptop). I move every few years, so the portability of the console design is appealing to me.
I have an old console that has a working radio/8-track and two speakers, but the turntable looks like someone took a hammer to it. I am not sure if anything can or should be salvaged, but I am willing to try it. I know enough about soldering, woodworking, and electronics to fumble through things, but I am not well veresd in how to go about putting a functioning system together.
Does anyone have any adivce on where to start with this? Should I use the old stuff and add new stuff to it? is there a way to tie my phone/laptop to the old radio/8-track? Do I need to start from scratch? Any advice anyone can provide would be appreciated. Thank you.
Welcome, Drajel. I see this is your first post.
Start by showing us pictures of your old console so we can see what we have to work with.
A search for an SKTRC 580 bears no fruit. Could do with a clearer photo of the label when you get the chance - and a photo showing the overall size of the console.
Is this your console? Is the name 'Soundesign' on the label?
"Many Soundesign stereo consoles from the 1970s featured a turntable, an AM/FM receiver, a single or double cassette player and recorder, or an eight-track player and recorder."
I see your model has a headphone jack.
More photos here: Vintage SoundDesign Stereo Console and 8-Track Tapes | EBTH"Soundesign consoles from the early 1980s added features such as a headphone jack and clearer sound quality. Many Soundesign consoles from the late 1980s were no longer made with an eight-track player and recorder but still had great sound quality."
Yes! that link you posted (Vintage SoundDesign Stereo Console and 8-Track Tapes | EBTH) is it!
Also, here is a close up of the label that can actually be read.
I really appreciate you sticking with me for this.
OK. My first thought is that if the record deck is absolutely trashed, similar second hand replacements, e.g. Garrard SP25, are readily available.
My second thought is that it would be nice to retain the 8 Track recorder/radio for its period looks and charm. 😎
I suggest you remove the deck and photograph the board on which it was mounted. Also remove the 8 Track and photograph the record deck input sockets and any other connections on the rear of the unit.
Am I correct in my understanding that there are just two full range speaker drivers and no tweeters?
I'm just having some fun investigating Soundesign, a company of which I'd never heard before now. 🙂
This site shows a similar Soundesign console (SKTC 540) fitted with a British made BSR record deck.
Phonograph/Eight Track Tape Player/Radio - Phonograph, Console
Yes it only has two speakers.
The 540 is about 2/3 the size of mine and in some ways that would be nice.
Here is a link for the pictures. I am travelling today and my mobile doesn't let me upload to this site.
Radio Stuff - Album on Imgur
Thanks for the photos!
Before proceeding much further, are you absolutely sure that the radio and amplifier sections of the 8 Track recorder/player are working perfectly?
The 8 Track obviously has only one external input (that to which the turntable connects). A switch could be added to enable you to toggle this input between the turntable and a Bluetooth Receiver (via which you could listen to music stored on your cell phone or computer).
How does that sound as a way forward?
P.S. In all probability the record deck has/had a ceramic cartridge and not a magnetic (MM) one. However, best if you could verify this, perhaps by posting a photo of the cartridge.
Thanks for chipping in Tim. 🙂
Drajel says the turntable looks like someone took a hammer to it and consequently hasn't posted a photo of it. Perhaps now he will, or at least comment on its condition further.
Soundesign certainly used British built BSR decks in its consoles. These early decks have a standard mounting board pattern so a replacement should simply slot in if required.
Awaiting a response from Drajel regarding his favoured course of action.
Hopefully the electronics are in working order. I assume the phono input is RIAA equalized, not the best way in.
There are R&L mic inputs, to record onto tape. If they work, that might be the best bet. You could parallel a 3.5mm stereo jack with those mono jacks. They are probably expecting a lower voltage than a phone or laptop, so attenuation of some sort may be in order.
Drajel, you said yours is bigger than the one in the photo. Is that just empty furniture size, or are there more features/speakers/etc?
- Design & Build
- Construction Tips
- Need Help with DIY Console Build
