Need help with discrete op amps.
I really want to build a set of these for my Rotel RCD-990- especially since I saw all of the circuitry the AD-817 has in it. A few questions:
1. Will the discrete devices have enough drive?
2. If I go with all jfets, which are best.
3. What's with all the extra circuitry in most of these chips?
Thanks for your replies in advance
What do you want to build?
1) drive what?
2) depends...
3) Assuming you are tlking about the schem for the 817... most of them are current sources and mirrors, pseudo-resistors & capacitors made from transistors.
Well.............
Preferably the output will produce the standard +-2Volts and be able to drive a somewhat low input impedance such as a tube amp. I want to use jfets because they are self-biasing- and are low noise. I want to use them both as gain stages and current sources, yet keep the parts count low. I will probably custom-make my own pcb's for the modules should I choose to build them.
...... especially since I saw all of the circuitry the AD-817 has in it.
Yes, in an IC op-amp can be 20-30 transistors! even in the less advanced
and signal may have to pass 7-8 transistors from input to output.
When I build a discrete preamp / op-amp
I not often endup with more than 8-10 T
and signal wont pass more than 3, maybe 4 devices.
You know there are 100 and 1.000 Op-Amps for sale and they are all different in some details, and in what they are intended to do, be used for.
It is same for building with discretes. 1.000 of possibilities.
So member poobah question is valid:
One of the first questions we need find an answer to:
What is the environment your discrete op-amp will live in?
Between a source and a load is where every amplifier is found.
A good description of those 2 factors, is what we start with.
This can be several different sources / loads to make your amp more generally useful.
But can also be a tailor made custom preamp for a very specific job.
Between for example CD-player Brand1-xxxx and Power Amplifier Brand2-xxxxA3
lineup 😉 one generally useful diyAudio member
