I have a 16-st1500 Memphis class d. I got it used in the trade not working Took it apart and found out some of the FETs for the power suppy were Smoked. Order new ones same part as befor. Replaced alll of them and the 494 chip the power suppy controller. After all that when you power it up the relay clicks over and powers up all good for about 5 to 10 secs then makes this squealing noise and starts pulling alot of amps so i turn it off. i need a few pointers have not ran into this issue before. Also for test purposes I have a Memphis 16-st1600 in working order that ive been using for specs and info. If you need anymore info just let me know.
Thanks shawn
Thanks shawn
Hello Shawn,
It would be good if you can post a picture of your amplifier board so it will be easier for the knowledgeable folks here to help you.
Thanks.
Thanks.
And in caraudio section people might know the amp.
(and there is a (speaker) load on the output of the amp ?)
Maybe a good idea would be to fix the cause of the catastrophic failure? Switch Mode controllers don't usually fail on their own.
Thanks everyone for your input hear are some pics of the amp. And i though i had found the cause of the issue but i gess not.
![url]](/community/proxy.php?image=http%3A%2F%2Fimage%2F3tc84acvr%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fs31.postimg.org%2F3tc84acvr%2Fimage.jpg%5B%2FIMGDEAD%5D%5B%2Furl%5D&hash=9d5550ed1d8a817b42726ebd8d89728c)
![url]](/community/proxy.php?image=http%3A%2F%2Fimage%2F429su7po7%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fs31.postimg.org%2F429su7po7%2Fimage.jpg%5B%2FIMGDEAD%5D%5B%2Furl%5D&hash=cd181d38ba7bf176823afcb25987c278)
Also ya i dont not have a schematic. I wish i could find one if anybody know were i can get one that would be great 🙂
And i have no load on it or rca. Just hooked up the power on my test bench. 20 amp Power supply continuous @ 13.8 volts
Connect a load or speaker. Always test classD with load. Unless you have manual explicitely stating it is allowed to be powered without load (means it has some protection, with open output classD output normally will start to oscillate, parts can get real hot, could even squeal I guess)
Thanks for the info. I gess i assumed it would be ok because the other amp did not do it, and as we all know assuming thing is a bad idea. When i get off work i will try hooking it up to my load bank. If that dosent help anything all post a video of whats going on.
Class d can do odd things with no load.
The 2092 based class d amps can have the output sit at +17V.
If the amp does oscillate then with no load to damp the output filter the output filter choke will ring at very high volts and possible blow output filter capacitor and/or other components.
Thanks again for the info. Tryed puting a load on it tonight and no inprovement. Hear is a link to the video i took of the issue happening. This is at 13.8 tell it over loads my power supply and a 4.2 ohm load on the speaker out put.
http://youtu.be/zinskfiXPdw
http://youtu.be/xo1VJBjhBn4
- Class D
- Need help with amp repair!
