Need help to get rid of noise
I have an amp that somehow makes noise that looks like a square wave around 1kHZ, and it gets to the output amplified. It's only present when the amp is turned on, so it's coming from the amp itself. The output (both channels) looks like this when no input signal is present:
wGk4mlVBdk8tQAAAABJRU5ErkJggg==
I'm also attaching the schematic. The amp doesn't even have digital circuits apart from a digital clock IC, and that doesn't seem to generate 1kHZ at any pin. So where is that noise coming from? :confused:
  • schematic.pdf
  • schematic(1).pdf
Try to identify the problem area by scoping the various modules in the amp to see where the issue is generated. Usually this kind of problem occurs in a negative feedback loop or through coupling through the psu. I would suspect a faulty capacitor somewhere but without a bit more diagnostic info that's about all I can say.
