Need help to find Extended ribbon cable for Lilliput 318gl 70 tv/monitor
hY
Recently I bought Lilliput 318gl 70tv/monitor
But I am not sure to use its Lcd because the ribbon cable is so sort to comply my demand.
I am seeking help from the fforum for any suggestion.
And where can i found extended ribbon cable?
Another thing about lcd that, is it reflective or transmissive in Lilliput 318gl 70tv/monitor.
I have already opend the back cover and saw that these things may be complicated than other lcds.
Pls Help
Bye
hY
Pls Help
Bye
I to ran into ribbon problems with my liliput. Its the 8" one. I tried two longer ribbons with no luck.
First count how many conductors are on the ends. Doing this can be a pain cause they are so small. I used a small flat head screwdriver and moved it along the conductors and counted the clicks. Do this a few times so you end up getting the same number.
then try this site. http://host207.ipowerweb.com/~diybuild/catalog/
