Need Help on ac/dc converter@!!!!
Hello Masters🙂
I have a problem regarding my ac/dc converter 12vdc/5a output.Recently I measure the output voltage with the use of a multimeter.I got the actual measurement of 14.5v,which is above normal than the specs.is there any way that I can put it back to 12v? I check the internal parts no burn @ all.inside there is IRF820and smps10 rctifier.next time I'll post the converter..
