In your very first picture we see eight three-pin devices, PER channel! I don't know about anyone else...but if a device, any device has a heatsink tab & and/or hole bored thru it , I'll put a heatsink assembly on it ...I don't care if it's running at a tenth of its rating, even a derated value, put a heatsink on it!...that's why those tabs are there.
-----------------------------------------------------------------------------------------------------------------------Rick...
Looks like it's KK's version of the Balanced Zen line stage: https://www.kk-pcb.net/bls.html
Original project document from Papa: https://firstwatt.com/pdf/art_bosoz.pdf
Chassis mounted chip amps, probably 3886.
Down at left and right on picture, using case as heat sink.
Thank you so much for the feedback everyone.
I started them today. Worked just fine. It was probably a good buy for 250 Norwegian kroner (approx. 25 USD) :-D
- Need help identifying these
