I need help identifying a TI SMD chip. It is a 8 pin smd chip.
First line say "23621". Second has TI symbol then "84M".
Third line has "A8N4 G4". The gnd is pin 4, the output id pin 8,
and I believe the V+ is pin 5. Any help would be much appreciated.
What kind of SMT package? Generally SOIC and bigger have an identifiable p/n. Smaller parts (SOT, MSOP,...) have a code indicating p/n, but it's usually 3 or 4 characters. The 'G4' is the ROHS indicator.
A legible picture would be worth a thousand words.
Here is the IC. It is clearly a TI.
Hi gray,
Yep, that's an SOIC8 package.
You're looking at a TLV2362. Product page is at Operational Amplifier (Op Amp) - Standard Linear Amplifier - TLV2362 - TI.com.
The last character on the first like is the letter "I", not the number "1". It signifies a -40 to 85C operational temperature range, typically referred to as the "automotive" temp range.
Thank you very much. Even with the picture TI tech support didn't know what it was. You've made my day.
Evan, I think you've solved one of my problems on another project with this. Thanks again, twice as much.
I need help to identify a SMD chip. It is a 16 pin smd chip.
First line say "96C5H0T". Second has say "6C596C4" or may be "6C596G4".
This is Texas Make SMD IC
Help me out to find this IC
- Design & Build
- Parts
- Need Help Identifying Texas Instrument SMD IC
