Need help identifying an amp.
I picked up this amplifier as part of a lot of items at an estate sale. If anyone can identify the circuit and determine what tubes it requires, that would be helpful. There are no markings or brand labels anywhere on the unit. Thanks in advance.
It's probably a custom build or a kit from tubesandmore (Antique electronics) or another tube supplier.
Judging by pic #1 and #2, looks to be cathode biased by the looks of the wirewound resistors to the ground copper wire. Basically what astouffer said. The addition of the heatsink to the power transformer is curious, it shouldn't need that if it's not being pushed to its limits...
The B+ is around 350VDC.
Agree that it's a 6BQ5/EL84 single ended amp. The 5Y3 should do for the rectifier.
Measure the output tube cathode bias (large green) resistors.
If you reverse engineer the driver schematic and resistor values,
the driver tube type probably can be determined.
Most likely 6BQ5/EL84 single ended with a 12A*7 driver.
That was my guess on the power tubes, any thoughts on what rectifier would work? I have a 5R4GB on hand, wondering if that would be compatible? I assume the center nine-pin socket would be the driver, with the two outer sockets for the EL84 valves. I have plenty of 12A*7 variants on hand, so almost there. I need to get a matched pair of 6BQ5/EL84, as the last two I had just went out with a sold amp.
Thank you!
Yeah, the inside sure does look similar, but for the tubes, they say:
  • Preamp tube: 1 x Chinese 6n1
  • power tube: 2 x 6p14 (EL84)
  • Rectifier : 1 x 5z4p
The heat sink on the power transformer is probably just for the "cool" factor.
