Need help fixing an odd Phase Linear 400
I recently bought a relatively inexpensive "As Is" Phase Linear 400 series II off of E-Bay. The seller was selling off a lot of lab equipment (oscilloscopes and whatnot), and it looked like this PL400 had been re purposed for lab use in some manner.
When it arrived, the first odd thing I noticed was that the RCA input jacks had been replaced with BNC connectors. I hooked up some cheap satellite speakers I didn't care about and powered the unit on. The LEDs come up on the meters, but I got buzzing from the right channel and nothing from the left channel.
Upon cracking the case open, I saw that all of the output amplifiers and driver transistors for the left channel had been removed! And this is what the main board looked like:
Several components had been removed. After comparing against a schematic I found on the internet of the PL36 board, it looks like the following was removed:
* two 3.9k Resistors (R212 and R112) The PCB is dark brown where these resistors used to be, so I assume they burned up.
* One FPN 3569 transistor (Q102)
* The leftmost 40327 (Q101)
* Both LF356h's (Z101 and Z201)
* A diode (1N4744)
I bought 12 MJ21196's for the amplifiers and 4 MJ15024's for the drivers off of DigiKey. I also bought replacement LF356's, a 2N3440 to replace the 40327, and the appropriate diodes and resistors to replace the other missing ones. I've also tested all the resistors in the unit with a multimeter and the appear to be fine.
My question is, what's the best order to replace these parts to minimize damage to the circuit? Should I populate the PL36 board with the replacement parts before I replace the output transistors so I don't risk blowing them?
As far as test equipment goes, this is what I have:
a digital multimeter
a nearly 50 year old Tektronics 585 oscilloscope.
Several cheapo Insignia satellite speakers I don't mind destroying
What I don't have:
A Variac
Experience fixing amps
Any help would be appreciated. I'd like to avoid ordering more replacement parts than I have to.
When I repair my amps I usually disconnect the output transistors and feed the output of the VAS back into the LTP to test the driver.
The VAS stage should output a pair of voltages that track each other by a few volts.
If the driver works OK I would then turn the bias right down and connect the output transistors but only one pair.
If your driver isnt working then I would remove all transistors and check every component on the board.
While the transistors are out I would check the HFE on them.
One fault I had was a transistor with an HFE of one !
Its all slow and hard work but you get there in the end doing it logically.
Sometimes its more than one component that has died.
PL's by design will sort-of "function' without output transistors. It should have normal offset and drive a 1k ohm or so load with the outputs and/or rail fuses removed.
Start with no outputs or drivers then if all goes well add them first and rough-check the bias. Make sure the Vbe of the combined positive-side driver/output is under a volt - which will keep them from turning on hard the instant collector voltage is applied. If that's in the ballpark, put in rail fuses and check bias.
Variacs won't help PL Series 2's anyway. At around 30-60VAC, they act "stupid". Horrific DC offsets, even audible oscillations. Sometimes they "squeal" a bit during power-down. Use a "light bulb limiter" when servicing these. It still goes through the oscillation phase as it comes up, but it will drive right through it.
Thanks, I'll swing by Home Depot and get a bulb socket.
Which way do the LF356h's go in? My board takes the 8 pin DIP chips, and the schematic I downloaded shows them in the "can" packaging. The two PL36 schematics I found online don't exactly match the board in my PL400. The layout is slightly different, and there are two 12k resistors on my board that aren't on the schematic.
Also, the schematic has two large 1.8k 5 watt resistors where my board has two 3 watt 7.5k resistors. I don't know if those are the right values for this board or if it's something the previous owner put in for some reason...
There are quite a few minor variations on the schematics. I doubt I've even seen them all - and I've been playing with PLs since 1980.
On the op amp ... pin 8 to the +15, pin 4 to the -15. The rest of the pins should line up. It's easy enough to trace the main +/-75V supply through the shunt regulators.
The big sand-box resistors are supposed to be 1.8k, 5 watt. They run hotter than the blazes of Hell and damnation - and one of the main failure modes is thermal cycling and oxidation where they solder to the board. I always touch this area up at a bare minimum. The previous owner may have replaced them with a higher value hoping to reduce the heat. I replaced each of these resistors with three 5.6k 3 watt MOX (flameproof) resistors in parallel and used the leads to beef up the PCB traces on the PL400 I'm using.
There are 7.5k resistors, but they are 1 watt and are the collector loads of the VAS. They run a little warm, and it never hurts to check their solder connections. They used a higher value (18k or something) in early versions.
I hooked the PL400 to a light bulb in series with the power supply and powered the unit on without making any changes. The bulb glows brightly for a moment, then dims. The LEDs on the PL400 power up as normal.
Then, I replaced all the missing components on the PL36 board (but leaving the old output drivers and whatnot) and powered the unit up. Bulb glows brightly, LEDs on the unit do not power up.
I removed all the output transistors and drivers and powered the unit up. Bulb glows dimly, LED powers up.
I put 4 new drivers in and power the unit up. Bulb glows dimly, LED powers up.
I put one bank of 3 output transistors in and power the unit up. Bulb glows brightly, LEDs do not power up.
I'm assuming this means I still have a ways to go. I'm going to reheat all the solder joints on the board and recheck all the resistors and whatnot. Is there something more specific I should be looking for?
I've fixed a few Phase 400 Series II's and have to warn you they can have some serious stability issues due to their rather odd design using an op-amp in place of the usual input stage. Bob Carver, as has often been the case, seemed bent on being "different" with his designs and the 400-II was no exception.
The relatively high open loop gain of an op-amp was probably why he thought it might be superior (especially in terms of damping factor which was a popular spec in those days). But it also presents some rather unique stability/compensation issues. There's a reason few commercial designs have done anything similar.
In my experience the 400-II is quite fussy as to driver and output transistors even when they're the correct part number. I also believe there were several revisions to the design during production to correct various problems that cropped up--some stability related. The early ones were kind of half baked.
And, running the amp on low AC line voltage (as created by your light bulb for example) may cause the power supply to the op-amp to drop out of regulation. And that, in turn, exposes the front end to ripple on the power rails which the op-amp should be able to reject but doesn't seem to like in practice. So it's possible your circuit is either oscillating due to low voltage and/or unable to reach a happy DC operating point due to the light bulb.
So the light bulb *may* be full on because the amp is oscillating or just can't reach the correct DC operating point. It could also be a wiring error or dead/incorrect component somewhere. A scope will tell you if it's oscillating as it tries to power up.
Some 400-II's had some significant turn on "thumps" so that might also contribute to a DC operating point issue. It's possible the circuit is trying to power up normally and in the process the light bulb is interfering--i.e. it *MIGHT* be OK if you took the bulb out. But you could blow a lot of transistors finding out the hard way. It's much better to figure out if there's a wiring error, a dead component somewhere, or if it's oscillating. But with no load connected most amps don't have a problem with low voltage causing massive current draw so something else may well be wrong.
Also, the dropping resistors for the op-amp power supply, as pointed out, ran WAY too hot and cooked everything nearby on the PCB including the solder connections. So that's probably why you're seeing different values. The factory resistors were too low in resistance and in their power rating. And be aware of any and all nearby components and solder connections. Also check to make sure the op-amp is getting a properly regulated supply even when the rails dip under load (when and if you get it working).
To figure out the op-amp pinout, just trace the power pins back to the big power resistors and see which rail they go to.
Overall the only thing I really liked about the 400-II were the cool (for their day) LED meters. And, of course, it was cheap on a dollar per watt basis. Frat houses everywhere loved them. Until they blew up (and sometimes took speakers with them). I've heard it's very rare to find any these days that haven't been repaired at least once and some (like yours) have been hacked to death because the original design had so many issues.
Personally, I'd be tempted to give up on Carver's 1980 "better idea" and use a 2007 solution like the LME49810 which should drive the 400-II output stage (or otherwise make use of all those transistors you bought). And you can dump that toaster of an op-amp power supply too. The stability, distortion, noise and slew performance should all be significantly better than the Carver design plus you get the Baker Clamp clip circuit. There are some LME49810 boards out there including the driver board from http://pansonaudio.com (panson_hk here in diyAudio) that should make it a relatively easy upgrade if you can sort out the output stage, Vbe multiplier (bias tracking), etc.
And, finally, you may want to replace and upgrade the main power supply caps if you can find something better that will fit. They were seriously undersized and, if they're the originals, are now nearly 30 years old and electrolytics don't age very well.
If the lamp is continuous lighting then there is a serious short circuit somewhere.
In my experience it is usually down to an output transistor gone or a capacitor gone short.
If there is a problem with the bias stage then just putting in new output transistors wont fix the problem.
What I do is remove all transistors and check them for hfe on a multimeter. While the transistors are out I also check resistors for value and caps for shorts.
I connect the VAS output back into the LTP to check teh driver is working OK.
Then I would turn the bias down to zero and reconnect the output transistors.
By this point you should have found the problem or have a working amp.
Not necessarily. As I said above, the odd design of the 400-II using an op-amp for the input stage makes it behave differently than most amps that use a discrete input stage at low line voltages. If the op-amp is slammed against one of its rails because it's not getting enough voltage, the entire amp is thrown off balance and may well try to draw more power from the AC line (lighting the bulb).
There is no problem with the amp slammed against one rail so long as the speaker isnt connected.
At this stage a speaker shouldnt be anywhere near the amp until it is proved to be working.
I've seen several amps that work perfectly fine that won't power up with a light bulb (or similar current limiting) even with no load connected. It depends on the topology of the amp. The DC feedback loop and/or VAS stage in some amps needs to be established at something near the correct operating point before the output stage will behave and bias correctly.
A lower than normal voltage and current limited power supply can set up a feedback loop where what would normally be just a brief current blip during power up creates oscillation or otherwise prevents the amp from powering up normally. Your advice for turning down the bias is good as really high bias could be causing the problem. Of course one needs to figure out which direction that is on the trimpot and it's also possible the bias circuit has a problem.
But yes, I agree you certainly shouldn't have a load connected while testing. Blue lander has explained he's already gone through much of what you describe regarding not having the output devices connected and the amp powers up OK. And they're brand new output devices. So it's not likely a short or a bad output transistor as you suggest.
But I have been there before.
Fitted new output transistors and there is still a short because there was a fault with the bias stage causing both output transistors to switch on and short out the power supply.
He needs to check the output transistors again, just in case.
That is good advice. Even with most cheap DMMs you can check all the transistors for obvious shorts. If they seem to be shorted while in circuit desolder at least 2 of the leads and test them again. If you need help on how to test a transistor with a DMM, just ask 🙂
And, as mentioned, look really hard at the bias circuit (everything between the bases of the driver transistors). Make sure everything is wired/installed correctly, are the correct parts, nothing is open or shorted, etc. And it could be something as simple as the bias pot is cranked to the wrong end of its range.
But, seriously, depending on your DIY skills, the LME49810 solution may be worth seriously considering. You could end up with a very nice amp that way. Also, another tip is to look on eBay for speaker protection modules from vendors like diy-gene. Assuming there's room in the rather odd 400-II chassis to mount such a thing, it might be cheap insurance. Fuses often do a lousy job of protecting speakers (or for that matter the rest of the amp) against a failure.
A quote from AmpsLab on the page linked above:
"The bane of Phase Linears, instability, has been resolved with this Model 200 Series2. After much analysis and redesigning, this Phase Linear remains stable in operation. "
Instability can also be a serious problem with the 400-II. I'm not trying to be unfair, as I've met and hung out with Bob Carver on a few occasions and he's a smart fun guy. But times have changed since the late 70's when Phase Linear had a strong following. There really isn't much to like about any of the Phase Linear designs by modern standards.
They were generally under heatsinked, had undersized power supplies, tended toward instability, mostly used inferior quasi-complimentary output stages, lacked a lot of modern day distortion reduction techniques, used drivers and output devices that are vastly inferior to those available today, lacked modern protection circuits and suffered from other assorted issues like some really marginal engineering (i.e. the red hot resistors in the 400-II). And some, like the 400-II, used poorly conceived topologies.
They were popular because, in the 70's, cheap high power amps were rare. And they tended to be marginally more reliable than some of their competition (like the infamous Ampzilla) but they still had the well earned nickname "Flame Linear"--often from instability issues and/or the lack of sufficient heat sinking. Carver did a great job of turning out Phase Linear amps with an impressive dollar per watt ratio, and some of them even looked cool, but they're otherwise vastly inferior to lots of later designs.
Its called making things down to a price.
I was in computer system design and quite often on high number runs we were asked to cut every penny we could.
If your churning out 10,000 units each penny saved gives you £100 back.
Agreed. And, in that regard, Carver did a brilliant job with the Phase Linear amps. I just wanted to clear that, while they may have nostalgic value to some, and be a decent source of cheap watts to others (like perhaps Blue Lander), they're otherwise not generally worth investing a lot of time or money in except perhaps to use the chassis, heatsinks, power supply and (if applicable) metering as a starting point for a DIY project based on a more modern, stable, reliable and better performing design.
I should add many ended up in semi-pro use for live sound, DJ duty, etc. with huge fans behind them to keep them cool enough. While nowhere near as robust as say a similar vintage Crown, they were much cheaper per watt. So that may also explain why there are so many Frankenstein-like examples around today.
I'm going to check all my new transistors to make sure they're good. I bought them from Digi-Key and just assumed they were good. Do I need to put each and every output transistor in for testing? I only ask because they're a gigantic pain in the butt to screw in and out.
Assuming the output transistors check out, I'll remove all the transistors, check them, and check the values on the resistors and caps. I'll also set the the bias to zero and double check every component connected to it. There's no circuitboard scorching around the large sandbox resistors. They're actually sitting quite high above the circuit board. I assume the previous owner did that to keep them from cooking the surrounding components. It looks like s/he also touched up the traces on the board with solder, but I'll double check for breaks there too. I'll reheat all the solder joints while I'm at it too in case any have frozen.
The reason I'm bothering with such an ancient and fussy amplifier is that I'm trying to use it to drive my set of 4 Large Advent speakers. I wanted something "authentic" from that era to run them off of. I'm beginning to think I should have gone with a Crown DC300a, though! Although the LEDs are really cool...
