Need help finding this part
I received this amp that was missing alot of pieces, i finally got to to the point where its missing one part. OP1 on the picture , i know its a optocoupler, but i need to know the part number. The amp is an audiobahn a275hct. If someone can that help that would be great. I think other audiobahn amps are made the same.
I think it's likely a KTC117. I doubt that you'll find that part unless you can get it from audiobahn or from a manufacturer using a similar design like power acoustic.
If you can't get an exact replacement, a PS2503-1 may work.
http://www.cel.com/pdf/datasheets/ps2503.pdf
