Hey guys!
I've just built a simple proto preamp for a guitar practice amp that I want to build. It works well and all, but...
I want to order some proper PCB's for the project, with PCB mount tubes. I use the "tubes"-library from cadsoftusa.com. How do I get the heater in with the two triodes in the schematic?
I've tried to add a separate heater, but it won't add to the excisting tube. This is a bit frustrating 😛
Thanks for any help!
Here you have all the libraries that I have. Here you can find a folder called "tubes", this is what you need to add on this case but all's are usefull.
Libreras_Eagle_CAD.rar
