I was lookin for specifics to help someone,but all Kicker gives is a sealed and ported specs and not any general info in thier Manual.
On thier site it says the 06 which is rated the same as my 05:
Resonance frequency[fs],HZ = 34.0
Total Q-factor[qts] = .513
Equivalent volume[vas],ft3(l) = 2.2(62.5)
My trunk can fit around a 32X13X13 give or take a inch.
Ive had Bandpass in the past and love it........I looking for the most Boom for the Space I have.........I was wondering if 2 speakers in a sealed box would hit harder or one with the correctly designed box would hit harder.
I listen to technoBass notes/Rap and alot of others includin country..hehehe
But I like to have really low bass hittin capibility without losin alot of clarity for my country days.
Thankx for all the help guys.
Joel
Joel
I think your box is too small to go with bandpass...
I'd go with a ported enclosure of 13x13x32 tuned with a single 4" diameter full length precision port.
I going to make a 2 piece box and make it 6th order!!
2 cubes each side........one to 35hz the other to 78hz.
Its just killin the ported box down low and up top by 3-5dbs and has a nice slope.....
What do you think???
Any programs out there to design or draw your box out good as Ill need to put it together somewhat in my trunk
13x13x32 = 11.5x11.5x30.5 assuming you're using 0.75" walls.
That's 2.3 cu.ft internal net. Now remove driver volume, braces and port volume, you're probably at 2 cu.ft.
There's no way you're gonna fit 4 cubes in that space.
To design a box, you could use a CAD program...
A full length precision port is this :
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=268-352
Are there any free Cad Programs out???
I was thinkin about makin a 2 piece box and semi buildin it in the trunk
Looks like it is best just to build a ported box at around 40-44hz with a subsonic filter on it for 30-35hz with a 24db cutoff to avoid over excursion under that ........
What you think??
What you think??
Bah, I was thinking tuning it with a precision port like I've showed you. That would tune it around 27 Hz then add a subsonic at 25 Hz.
doin that I have a major cone excursion at 47-67hz at 750watts or more.
The rms is 750........I was tryin to get around 900 safely without over excursion???
- Subwoofers
- Need help designin a box for a Kicker 0512L72
