Need help and/or advice - analog (RCA) to digital (S/PDIF) converter
Hello and good evening
I wanted to connect my vintage gear to a DCX-2496 (AES-digital input) and have bought a cheap (16€) converter because it`s the easiest way to change between USB-PC and stereo amp. or tape deck out. Just one lead from one converter to the other.
The converter is working very well from 20Hz to 8KHz but then sharply drops. Thanks DCX I can set a filter to correct the frequency response but this workaround actually is second best.
Amazon is selling a lot of similar converters but all of them are reviewed badly. Same electronic design, different housings - I guess.
My converter has a bit different layout. It has built in a Cirrus Logic 5340 as A to D and a CS8406 as transmitter to Toslink-S/PDIF. Well built, I have to admit.
1. What do you think causes this frequency drop? A wrong input stage design? Where do I have to look for?
2. And - although I would be willing to spend more money, I couldn't find a better converter. No matter how deep I googled.
Thanks in advance and stay healthy
If you can, check the component values in the input stage. If any of these were the wrong value (say off by a factor of 10) that would give exactly the effect you describe.
There used to be a DIY-kit for an ADC in very good quality from beis.de, might be worth having a look through those pages to see if either of them work for you (there are several versions/revisions by now).
I want to let you know that I have given up and that I'm now going the analog way into the DCX2496.
It was to hard if not impossible to read all the component's values. So I sent the converter back.
And sadly Mr. Beis didn't answer my email.
Again thank you very much for your help and advice
Please excuse my very late reply.
In the meantime I have purchased a used Sony 930 QS Minidisc Player which also completes my collection of the QS series. It now works as a wonderful AD converter and digitally feeds the DXC. This works excellent.
I confirm that MiniDisk Recorders can provide quite decent AD conversion to SPDIF. That'a why I keep my MDS-JA555ES despite the fact that I'm not recording MDs anymore, but feed my DSP Speakers with the AD converted Phono-Signal.
Regards,
Winfried
