Need help: Aa driver not passing AC signal
Hi. My Aa driver tube is not passing AC signal to the coupling cap. I believe it might be caused by the LED bias which is measuring positive voltage (+). Here are the measurements:
Vac at Grid: 50mV
Vdc across filaments: 3.8Vdc, 0.5A
Ua = 160Vdc
Bias = 2Vdc (note, this measures (+) Vdc, not (-)).
Vac at Plate: 0mV
I have tried 2 different NOS Aa tubes. This does not resolve the issue.
I am curious about the bias. Using an LED. The + leg (long leg) is attached to the + filament pin. The - leg (short leg) is connected to ground. Yet, the bias measures positive (+). I thought this should have measured negative (-).
Anyways, no Vac coming from the Aa tube. Schematic and Aa datasheet attached.
Thoughts?
SOLVED: See #2 below.
  • Aa.pdf
