NEED GURU HELP ON THIS !!!!
Not recommended for a newbie - better for you to begin with a simple chip amp at a lower power level and work your way up. If you want to build a powerful amp straight off then find one available as a kit where the hard work of getting good layout has already been done for you.
The specific thing that worries me about this amp is the bias arrangement - seems to be handled by a 2N3055. But it does not show you that that transistor has to be kept on the same heatsink. Use of a TO3 type in this function is unconventional to say the least, there's also no pot shown for setting the bias up. All these missing details tell me you'll be best giving this design a wide berth.
<edit> Oh I missed that the '300W speaker' is being fed through a 400uF capacitor. You did say you wanted good sound? Steer well clear of caps in series with speakers, especially such low value electrolytics.
That 600W amplifier is fed from a 30-0-30Vac transformer.
The retailer lied.
The maximum power into an 8r0 load that this PSU will allow an amplifier to deliver is ~ 80W per channel.
If the retailer lies about the power rating then does that retailer have the integrity to offer adequate customer support if you run into assembly or operating problems?
Saw this schematic for the lm4702, and looks like an interesting new amp to build now my lm1875 amp is finished and up and running for a while. How does this chip compare to the gainclone lm's sound wise?
Thabto, i would start with an lm1875 or 3875 if you are a newbie, i did that too and you learn so much about everything really. This one has a separate output stage (if i am correct) which complicates things. Maybe you could built a power supply separate from the amp so you could reuse that one if you would like to scale up things. Power supplies are the biggest expense, on the component level off course.
Given output power, tone, and chip-amps for input information, your request then matches with:
TDA7294
Decibel Dungeon inverting LM3886
MyRef
PA150
BPA300
For cross reference:
Inflate maximum usable music output power of these projects by 400% and also multiply the resulting figure by the number of channels if you want to compare to PMPO mass market rated products. For example, TDA7294, 600 PMPO watts in stereo.
Going forward, please use output figures that also indicate performance, such as:
65 watts per channel at 0.9% distortion
80 watts per channel at 10% distortion (same amp playing louder)
300 watts per channel PMPO (100% noise, no music at all, probability of smoke)
See? Isn't that more descriptive?
When distortion figures are absent, hide your wallet because they're talking about PMPO, not music.
Of course, distortion figures usually decrease considerably when you turn down the volume knob. Unfortunately, that makes smaller wattage advertisements.
Check out these options:
A 25 watt per channel amplifier with 93db efficient speakers or
A 50 watt per channel amplifier with 90db efficient speakers or
A 100 watt per channel amplifier with 87db efficient speakers or
A 200 watt per channel amplifier with 84db efficient speakers or
A 400 watt per channel amplifier with 81db efficient speakers
The sound pressure output level is exactly the same for all five of those examples (all five equally loud); however, the dynamic impact and overall quality from the first example is the best quality on just 25 watts. Its because of the speaker.
See, speaker efficiency is a lot more important than watts!
