Need class-T with more output
I have for a while been using a Super-T and T-amp and really like the way they perform. But I could in some instances use a bit more power.
Anyone with experience with one of the higher-output kits - like the Fenice 100 or 41Hz Amp 1/5 (TA2022) or even the Autocostruire 100m (TAA4100A)?
You must have a very big room. I have modified my amp as per panomaniac's mods on his site. My speakers are 89db sensitive. I use a valve pre-amp and if I turn it up over half way I am deafened. If you haven't modofied it and it is as bought, you must do so. Run it with a 3Amp 13.8 DC power supply which will power the chip to it's limit and get the best out of it.
