Need advices on building a stereo tube amp from PCB
Hi guys,
I will start buiding a stereo tube amp soon, PCB based since I don't want to do point to point wiring since I am not confident about my planning, routing skills 🙄
I am considering a few bare PCB and kits (see below), anyone having an expirence building them ? Or theorical advices by looking at them ?
My dilemma is I know starting with DIY friendly kits from US/Germany should be a safer option, but Chineese kits are more complete and have apealing specs and tubes...
Main objective:
- $600 max for all but the case
- 8w per channel minimum with 8 Ohm load
- Looking for a warm sound
What are less or not important:
- Kind of tubes used
- SE or PP design (with respect of minimum power requirement)- Bass punch
- Absolute specs, I do it has a hobby and a way to continue my amp building explorations
Here are my shopping list:
- S5electronics K-16-LS full kit
Untitled (maybe with the tone tune module)
- German EL34 PP bare PCB
Platine f. Rohrenverstarker / PCB f. DIY Tube Amp 2x 6L6 / EL34 PP STEREO | eBay
- Chineese EL84 Push-pull class AB full kit or bare PCB
https://www.ebay.com/itm/Stereo-Push-Pull-Audio-EL84-PP-Vaccum-Tube-Amplifier-PCB-DIY-Kit-Board/253710058115?hash=item3b124c4283:m:mQx6EnyXdUcbDeDw8X6uyHg:rk:1😛f:0
https://www.ebay.com/itm/6P14-EL84-Push-pull-HiFi-Class-AB-Stereo-Tube-Integrated-Amplifier-DIY-KIT-13W-2/272970610465?hash=item3f8e50f721:g:VZAAAOSwNqFbe3jg:rk:1😛f:0
- Chineese EL84 single ended full kit (or bare PCB...)
https://www.ebay.com/itm/Douk-Audio-EL34-Vacuum-Tube-Amplifier-Single-ended-HiFi-Power-Amp-Kit-DIY-12W-2/281822570523?epid=2163192810&hash=item419def281b:g:YKIAAOSw~p1boe1c:rk:11😛f:0
Any help is appreciated 🙂
Bye
M33
George Anderson of tubelab.com has popular PP & SE PCB's with a Forum on this site so lots of help.
Pete Millet has sweep tube PP amp PCB's that could be adapted to regular in production tubes if needed/wanted, plus info on his site for other amps/preamps he has built with some PCB's for those also. There are threads on this site on his popular sweep tube PP amps also.
