need advice
coz,
I'm sure bigwill has got it right but just to confirm, you are wishing to block everything from 100Hz on down or do you just want to attenuate the 80 to 100 hz region?
If it's everything on down then a simple cap will give you 6dB per octave. If you wish 12dB then you will have to add a coil as well.
If you wish to attenuate only a certain area you will need a notch filter.
And as bigwill says, make sure you connect a bi-polar the right way, that is, with the prinitng upwards 😀
