I have a question:Which transisotr pair is better for an 150w in a 4 ohm load the MJ15022/MJ15023 or the 2SA3281/2SC1302.What i want is not only power but also a quality bass.
I understand the TO-3 case transfers heat to the heatsink a bit moreefficiency. This may be relavant if you plan heavy-duty use.
