Need advice: building Troels Mini Bookshelf, will add Woofer stand. Will this work?
Hello,
  • I had an old pair of Seas W15CY001, so deciding to follow Troels' mini : http://www.troelsgravesen.dk/SEAS_5INCH.htm
  • Later I would like to add 8" woofer separately for each chanel as speakers stand, woofer will be side mounted.
  • I possibly use Seas H1192-08 CD22RN4X
  • Woofer will use passive crossover. Connected to main speakers with external jumper. So these will work with single stereo amp.
  • Will the woofer works with this cabinet volume, and with this mounting?
  • Since the crossover for woofer is passive, is there anything that allow me to adjust and change the level (woofer), like volume control?
  • Any example of crossover, build guide would be appreciated.
Sorry if any part does not make sense, I have not much experience building speakers.
Any advise would be appreciated.
Have you thought about using a separate sub woofer amp? Since the drivers you mentioned are 8 ohms, you could run them in parallel out of the sub amp. This would also give you the ability to adjust the volume of the woofer separately and then with your main amp as the master controller. Plus, you would benefit from a built in low pass filter.
Mike
